evo 8/9 manifold/turbo on dsm pics?
we will see. had alot of ppl say itll melt, but i dont know if they figured itd have as much meat on it as this one. should have alot of heat dissipation ability between the head too.
if it doesnt work, i have a deal with the machinist to make me a steel one as well.
Melting point for aluminum is 1220 deg F while we may push up to 1600 deg F on a regular basis. Head exhaust ports are heavily water cooled for a reason. Good luck.
exactly. i actually commissioned him to make me a steel one anyway.
water pipe barely clears, but the water nipple closest to the WP needs to be bent or moved. clearance is pretty good on everything else, w/o it being in the car. could even do a downpipe off the stock o2 housing if you were crafty enough, custom would be better tho. the intake and maf are evo 8 pieces as well (pretty sure theres not a enough room for both on that side, but i have some pipe to make a custom intake, and plan on running SD after the evo8 ecu is in for a bit)
heres some more pics of it installed on the motor, enjoy
still need to get the right bolts/studs, ones i got today are too long.
  • For sale 2g 2G DSM Link V3
    • frosh29
    • The_Partout_Spot
    • The_Partout_Spot
