Please Support STM Tuned
Please Support ExtremePSI
2G bump steer kit/tie rod end! only kit in the world for a 2G! (Closed)!!!!!
EC17PSE
Freelancer
5,891
3,483
Nov 1, 2008
London, UK, Europe
Hello again Tuners, List closed!!!! 9/6/17
Welcome to my next item I have designed and developed in the quest for better suspension setup and handling for the 2G!
If you have lowered your car and/or want to add alot of caster then these are for you! they also remove any slack a ball joint may have and give ultimate driver feedback to the steering wheel for a more precise feel. Caster makes the connection area drop resulting in out of sync and and a massive issue for toe change in steering and cornering/braking! If you serious about handling then this is something you need.
These feature the same high end race Chromoly rod ends I always use and will continue to use for strength and quality.
ABOUT THE ITEM
Adjuster shafts a made from EN24T for amazing strength and have the same length internally as an OEM outer tie rod end so no loss of length or threads, spacers are also now EN24T to match and have offset heights for adjustment and washers are included aswel if needed, everything will be clear ZINC plated and will include rubber dust covers for the rod ends aswel, taper spacer inserts into the knuckle so no need to drill or reem the knuckle out! its what you would call plug and play to an extent.
Hardware will be a 12.9 socket capped bolt and flanged nyloc nut to secure into place.
For installation most of the time these will be placed above the knuckle like oem ones are, for those that are really low then you may try to use below the knuckle!
SETUP is critical to getting correct, the use of a bump steer gauge is best to get super accurate results, a link here walks you through best ways to setup and troubleshoot http://www.longacreracing.com/technical-articles.aspx?item=8162
When i tested my car out, oem tie rods vs my new kit i managed to dial alot if not most of it out all from the fact of lowering my car!
Lowering the car 2" sees a toe of 50 thou (1.27mm) uppon compression! this is alot!
Oem tie rods and lowered 1 1/4" produced 32 thou! (0.8128mm) uppon compression! Thats also a fair amount
My kit same ride height of 1 1/4" managed to get it to just 9 thou!!! (0.2286mm) thats much better and its also better then stock is at oem heights!
PLEASE READ DETAILS
Price is going to be an entry price for this batch of $250 shipped via FedEx, fully tracked and insured, after this first batch they will go up to $275 for all other batches, This is a very cheap kit compared to everything else on the market for a bump steer kit and its built by a DSMER for DSMERS!!!
list will close on the 10th JUNE 2017 minimum of 20 to enable me to go ahead and to continue to make them in the future, If these dont go ahead then i most likely wont produce them ever.
If you have any questions please as always feel free to PM me or comment in here and I will reply as I always do,
When sending paypal please include phone number as its so much easier for me to get all your details from 1 place,
1. GSXbooster (SHIPPED)
2. llxKevinxll (SHIPPED)
3. SlowWhite (SHIPPED)
4. Gsxitement (SHIPPED)
5. Zmann42087 (SHIPPED)
6. Greengoblin (SHIPPED)
7. Apache (SHIPPED)
8. Dskagr (SHIPPED)
9. TheLemon (SHIPPED)
10. Viciouslord (SHIPPED)
11. 99redgst (SHIPPED)
12. Apache* (SHIPPED)
13. Mantega4g63 (SHIPPED)
14. Chinola69 (SHIPPED)
15. tunedbysaturnsl (SHIPPED)
16. 95eclipser (SHIPPED)
17. 1point8LTpower (SHIPPED)
18. T2Small (SHIPPED)
19. Coloradotuner (SHIPPED)
20. Eclipse 1998 (SHIPPED)
ALL SHIPPED!!!!!
Thank you
Quite a bit of interest and a few to possibly come on board soon,
if anyone is unsure on these please do ask or pm me as i am here to help and im offering a product that IS much needed and is the ONLY kit for our cars that has EVER been built!
A stolen and recovered 97 acura EL led to an 06 TSX led to tight finances and a possible surprise this weekend :)
Might be living it up with the 2 car life and my DSM build since I got a beater back
Someone stole your car? Damn that sucks, always good to have s few cars incase 1 or 2 break down haha
Exactly! yea LOL took a week to get it back minus a few items. Broke the column trim and the ignition, but it all still works. I swear I cant blow it up or get rid of it if I try! Anyways back on topic, my bad...
Tough car,
Few more people in on them, thanks everyone,
I'm in for a set as well. Will send you a msg and money shortly.
No worries, look forward to your message. Bobby
Thats 5 on the list!
A month left to get in on these.
I'm still trying my best here but financially recovering from gsx number 2
Haha stop buying cars!!! And making me jelous its that easy for you lot! Im here struggling to find a block to rebuild LOL!
few more weeks left everyone, just getting it up there again for all to see
Thats 8 now folks, any one else want to get in in this batch? Just over 2 weeks left now,
So i have been asked why no 1G love and will these work on a 1G! Mainly because i dont have a 1G I cannot make things to test on them and the only guy i know with one here in the country means im not about to start taking his car apart for testing LOL
However since searching i have found the part number is the same for 1G and 2G for the outer tie rod ends, so from this my assumtion is this will and should work on a 1G aswell,
Mitsu part # shows MB910859 JnzTuning also list it aswell and all list for both 1G and 2G.
I might try and snag one or 2 sets in 2 weeks? you know I m good for it :p ? I might even scrape through a deposit if that's too late bobby...
Now I want a second set of rear arms too tho :D ...
wondering when that would be available
Haha no worries buddy, just give me a PM when your ready and we can go from there,
As for the arms, i am not sure yet, i want to get the other parts testing first
