JJLANCER02
- Jan 29, 2013
plano, tx,
Texas
Hello, my name is Javier I always wanted a get a gst back in high school. So I'm kinda new to this. I own an 03 Evo gsr w/ 462hp & 396tq. Last year on new year eve my Evo finally gave up on me. It threw a rod. I guess it got tired being in the dark. Then it cause a chain reaction damage from timing belt snapping so it a goner. It put a hole in the block the size of a coke can and a hair line crack from cyl 1-3. So I went out and pick up a 95 2g gst w/160k stock no mods except a drop in. Paid 1200 for it it not prefect it grinds in 2nd gear only when it hot outside but when it cold it shift in smooth. And also it has an oil leak near the oil filter,oil pressure unit. Is that a common problem that need replace. Also the heater don't work a/c does what other common problems can cause that before I start ripping out the core. I change the radiator fluid w/ a major flush. Thanks guy I've been owning Mitsubishi since I was 15year old and I'm 25 and only had two since then. So what other problem I can get a heads up on cause it a totally different beast any pointer would help. Thanks a lot
