hey hey! Im New Check Out My Ride Yo
newdesignz
Aug 3, 2008
chalfont, Pennsylvania
hey im new here kinda. i have a 99 gst im doing a awd swap to it. its a fully built 7 bolt motor with a fp 3065 and a jmf race manifold. its really clean well see what numbers i put down. ima be running 30 pounds daily driven. what do u all think
[/URL]
[/IMG]
[/URL]
[/IMG]
[/URL]
[/IMG]
photoshop LOL everyone im also from doylestown pa. im 21 and work at a machine shop in nj i bought my car bone stock and i have persoanal done all my own work and have tuned with with some close friends. cars come a long way. ive only been in the game for 2 years now.
also those pictures are from last year its been completely diffrent now LOL ill get new ones asap
Exterior...
AGX Adjustable Struts
RM Racing F/R Sway Bars
Custom Camber Adjustments
Eibach Sportline Springs
97 Black GSX 17" Rims
6000k HIDS
Poly Bushings
Interior...
Custom Black/Red Leather Seats/Door Panels
B&M Short Shifter
Greddy Shift Knob
Nakamichi Cassette Player... Bad Ass Headunit!
Memphis M-Class 6.5 Components
Memphis M-Class 6x9 Coxials
Memphis Power 4 Channel Amplifer
AEM UEGO Wideband Gauge
AEM TRU-BOOST Gauge
AEM Meth Progressive Pump
2 Gauge Pod Pillar
Greddy Turbo Timer
2g Eprom
DsmLink V3
Engine...
Eagle HBeam Rods
Wiseco 9.0:1 Pistons
ACL Race Rod And Main Bearings
ARP Rod And Head Studs
Balance Shaft Removal
FIC 1000cc Injectors
6AN Fuel Line
8AN Fuel Return Line
255 HP Fuel Pump
HKS 272 Cam Set
Fuel Lab Black FPR
Fel-Pro Headgasket
Forced Proformance Exhaust Manifold
Forced Proformance 3065r Turbo
Forced Proformance 4inch Intake
Tial 44mm Wastegate 1.2 Bar
Custom Fab V-Band O2 Housing
Custom Fab External Wastegate Dumb
1g 60mm Throttle Body
Shortroute Intercooler
Custom Fab Stainless Intercooler Pipe
NGK 1 Step Colder Plugs
NGK Plug Wires
Greddy Type S BOV
4AN SS Oil Feed Line
10AN Fitting Oil Return Line
JMF Coil Bracket
JMF Large Oil Catch Can
JMF SMIM "Race Version"
JMF MAP Sensor Adaptor
Custom Fab 3" Stainless Steel Downpipe
Custom Fab 3" Test Pipe
Custom Fab 3" Catless Exhaust
HKS Hi Power Muffler
Megan Strut Bar
Everstart 51-4 Battery
Poly Motor Mounts
Mobil 1 10w-30 Oil
Drivetrain...
SS Master/Slave Line
ACT 2600 Street Clutch
ACT Flywheel
Quifee LSD Diff
Ball Bearing Cable Bushings
Solid Shifter Bushings
Redline Oil
OEM Master Cylinder And Slave Cylinder
OEM TOB Pivot Ball And Fork
Mods...
Fuse Box Relocation
Coolent Over Flow Relocation
Full Wire Tuck
Cruise Control Elimation
EGR Elimated
PRV Elimated
Check Solinoids Elimated
Battery Relocation To Trunk
Trunk Cleaned Up
New Pictures...
i got a 51-4 battery i should show u my trunk its real clean and ill show u how i put it right in the corner. a 51-4 fits perfectly in there. i def like v2 better just because im getting use to all the logging but its so much easier to read the tables and to dial in to the dot
Yeah LOL im getting a honda batt to put in there LOL. Well I am so freakin confused w/ V3. V2 was sooo easy compared to 3. I just want somebody to come show me how to use it and what to do and I want my car tuned LOL. Like right now I have to adjust my TPS b/c the car shuts off at a stop if you dont give it gas and you have to go into dsmlink and dick with the idle settings and I dont know how and I am only getting 80% throttle with the petal the full way down and I dont know how to change it back to 100%. LOL its so frustrating!
yea a honda battery is a 51-4 battery. i wouldnt adjust the tps sensor through link. just calibrate it right using a multimeter. do u have any cel?
im new i never post anything. ive been in the game for about 2 years now. got my car stock and built it to what it is now.
but im posting cause i cant get into the new classifieds cause im new which is rough being i love buying and checking stuff out. idk why do that. is there any way i could get into it with out having a low amount of posts
