49178-54400
AllanL
274
25
Apr 24, 2008
LV, Nevada
anybody know the specs for this housing?
specs means:
1) for what compressor wheel?
2) max comp wheel that can be machined to fit?​
thanks...
possible to machine to fit a 20G wheel or bigger?
thanks Justin, as usual...
Depends what the inlet diameter is- your inducer spec can't exceed the inlet O.D. minus about 5-6mm for strength. In other words- machine the inlet too thin and the weight of your intake pipe will snap it right off the cover.
I wouldn't use a compressor with an inducer larger than that "step" at the leading edge of the cover there.
same housing? TD05-16G for a JDM Nissan or Toyota? what knd of 16G? small? big? evo3?
possible to use as 20G wheel?
thanks...
Toyota builds their own turbos, and Nissans use Garretts. The pics you posted clearly depict what is a Hahn Super 16G.
....this is the cover used on a Small 16G compressor to build the Hahn "Super 16G".
Not without machining. The 20G cover in the photo you posted is totally different.
    • sanmantsi72
    • El_marto
  • For sale 1G DSM 4G63 PARTS
    • The_Partout_Spot
