synchronic
- Jul 22, 2005
San Diego,
California
Hey guys, I wanted to post this here to see if anyone else has seen this same phenomenon. Our resident dyno queen is a 4G63 Eclipse GST. The turbo is a Mitsubishi 20G running on the stock manifold. It is an oil-only CHRA, no water.
Boost was perfect and predictable with every setting on the 40mm WG001. Port C, D, C+D, C+A, D+A were all consistent results when the car was first run. After heat soaking the car with F3 mode on the Dynapack, going in and out of boost, the turbo was glowing. Subsequent runs then started to make lower boost. I had to isolate if the problem was the wastegate, or some other problem in the system.
When cold Port C+A was making 20 psi of boost. When heat soaked, the exact same combination, without any changes whatsoever, was only making 16 psi. The boost also spooled up slower and didn't have the same curve as the cold setting. This difference between cold and hot turbo conditions was replicated by letting the turbo cool with a fan and then running the car again. Identical results each time. Engine temp was also consistent between cold and hot turbo runs. But this still doesn't isolate the wastegate from being the problem.
So, the next logical step was to run tests minus the wastegate in the equation. Luckily, the setup is somewhat of a slow spooling application. There is a maximum boost that the turbo will make at a given RPM with the wastegate completely closed.
With pneumatic pressure at the top of the wastegate to always keep it closed, I ran tests cold vs hot to isolate the turbo. With the turbo being cold and the wastegate held shut, the turbo made 20 psi at 5100 RPM. With the turbo heatsoaked to the point of glowing, the turbo only made 16 psi at 5100 RPM with the wastegate held pneumatically shut. It was also observed that the boost pressure was erratic when the turbo was heat soaked. Boost was moving between 15-18 psi in F3 Dynapack mode with the RPM held steady at 5100. The boost also seemed to come up very slowly compared to when it was cold. And, with the WG held shut and the turbo was cool, the turbo would make more boost as you increased the RPM. 5100=20 psi, 5200=22 psi, etc. When the turbo was hot, it would not make more boost as RPM increased, 5100=16 psi, 5200=16 psi. And this is with the wastegate held shut. The more RPM you drilled into the turbo, the more unstable it became as well. It would actually start to surge with more RPM.I believe that this test completely eliminated the wastegate from the equation as being a problem.
Anyone else see this before?
