Hiitman
- 482
- 3
- May 12, 2004
Colorado Spring,
Colorado
so i ordered a 50 trim and manifold from sbr with all the supporting mods (850s, walbro 255, ect) for my 95 gsx. spent the past 4 days installing everything and now that im done im starting to troubleshoot the problems. first off the line from the fuel rail to the fpr was leaking so i talked to some people and they said it was safe to stick the stock fpr on there for the time being. also had an issue with the oil return line being pinched but that was fixed. now onto the bigger problems. before i swapped out the fuel pump i was told to make sure that my tank was less than a quarter full so that my back seat wouldnt fill fuel during the upgrade. so.... my tank was already low from losing fuel from changing the injectors, fpr, fuel lines, ect. battery died from the alarm so i figured whatever...ill just roll it out of the garage and into the driveway to jump start. went to start it and nothing...dry crank no sputtering or anything. then i remembered the fuel so i stuck about 5 gallons in there. still nothing. but after it sputters a little it starts to smoke out the wastegate. so im thinking it could be one of two things...either i fried something intenally on the engine from lack of fuel or i somehow blew the turbo.
back to the troubleshooting...
