- 2,196
- 62
- Dec 29, 2004
Humble,
Texas
Well I got my new boost gauge in. The old one was def. broken, this one 0's out fine at WOT, now I suppose I have a boost leak, I got a whopping 1 that's right ONE PSI haha..Any tips or anything?
Josh
Josh
It does wonders, just slab that all around the house where it goes into the brass fitting.ddavisaf said:Is this a boost/vacuum gauge? What are you reading for vacuum at idle?
When the car is off, where does the needle sit on the boost gauge?
Boost leak test it
http://www.vfaq.com/mods/ICtester.html
91dsmtalon said:Are you teeing your gauge in there? I thought the best place was to tee it of one of the hoses (forget which) by the firewall. Maybe all that extra line doesn't help?
I wouldn't want to tap into the same line twice either. The only question I have is, is there any problems tapping into the same line twice?? Just curious.DSMcrazy3 said:That I already tapped the FPR line for the FMU, and I didn't wanna tap the same line twice.
Thanks anyway!
Josh
dalatinromeo said:is there any problems tapping into the same line twice?? Just curious.
