P1105 - Boost Control Solenoid
alIan
164
Oct 17, 2002
I have had this engine code for about 6 months now, and after reading up on the purpose of the BCS (WARM starts - extra fp), i decided that i'd be patient and just keep clearing the code every time it came up (about once a week). I checked my BCS with a vacuum pump and a v/o meter, and it works FINE. NOTE: my boost gauge is tapped at the BCS, in the correct place. Could this be the reason i keep getting the code somehow? can i bypass the BCS entirely and just forget about it?? i dont care if it functions, i just want this code to stop showing up :).
thanks
ian
check the code to see what the ecu doesn't agree with. Turn on/off the car 5 times leave on the fifth time and count the number of times the CEL blinks. (ex. 3 blinks,2blinks,1 blink, 4 blinks ====#3214) then consult a 'Chilton's' manual to see what that number refers to in the engine overhaul section. If you don't have one already, buy one.
P.S. I was under the impression that the boost gauge should be tapped into the intake manifold. not the Boost Control Solenoid? ??? :confused: If it's tapped at the BCS, then your reading what the turbo is putting out, not what is actually being forced into the intake manifold. Plus, it won't show any leaks in the plumbing, etc. :dsm:
You are getting the BCS (Boost Control Solenoid) confused with the FPS(Fuel Pressure Solenoid).
The BCS is by the aircan, the FPS is on the firewall by the intake manifold. The ECU checks the electrical signal to the BCS. If you have it removed because you have an aftermarket boost controller, you will at least need to have the BCS plugged in even if no vacumm lines are hooked up to it, to aviod the CEL.
Exactly.
wow i feel like a total moron :) i definitely know the difference between the BCS and the FPS, i just somehow wrote the wrong one down. my BCS is plugged in and no vac lines run to it. It is the FPS... i just dont want to spend 80 bucks on one at the god damn dealer (even though i tested mine per the hanes manual and it is fine).
If anybody knows a place to order solenoids CHEAP.... let me know PLEASE!!!
    • sanmantsi72
    • El_marto
  • For sale 1G DSM 4G63 PARTS
    • The_Partout_Spot
