larryriverside
- 116
- Oct 27, 2002
fergus falls,
Minnesota
i am sick of having my afc set in the -. for some reason i think i am rich, but i know that im not. i have data logged my car, and tuned it for 0-3 counts of knock. also my egts are below 1550 at high sustained rpms.(5th gear) i have 660 injectors, 255 lp walbro, 2g mas, 60 trim turbo@20 lbs of boost on 97 octane gas. my high settings are at +8 to +12 on the high setting. if i go lower i get knock. does this sound right? and what size injectors would you suggest to get me in the - on my afc. i think my computer is sensing a major load at +12, and backing my timing off. not sure. my timing goes to 16 at 4500, then to 21 at 6500. all with no knock. any opinions?
