AFC Settings w/new Setup.
ETE32TSI
Aug 26, 2002
Being as all of you guys are what I like to consider Hardsore DSM Tuners, I was wondering if someone could help me out with some basic fuel trims just to get me started, you can see my mods in my sig., I finally get my car back this Friday and this will be the first time I have it with all the new parts on it. It was stock before it went in under the knife. Any Help fellas would be greatly appreciated.
i started with 37 psi base line fuel pressure. i tuned the LO-setting on the s-afc right from RRE's site, and on the hi table i started at -0 across the board. at 15psi, make a few WOT runs in 3rd and use you're logger and egt gauge to make fuel corrections at rpm levels where you are getting knock. advance should not drop below 18*. im still having part throttle knock issues im dealing with:confused: i see the most advance with o2 voltage at .92 anything less and i get HUGE knock counts. my throttle points are at 30/60 hope that helps
hey thanx for the info., how do you like the ETE32?, I can't wait to get my car bqack, I'vce been staring at this turbo sitting in my room for like 3 months, now its going to be on my car :D BTW, Anyone else?
i freaking LOVE it, while tuning i get 15 psi at 3K. ;)
