tuning questions
stevetford
89
Feb 23, 2002
Wickliffe, Kentucky
Does anyone know what kind of timing they run at around cruise/light throttle speeds and then timing under boost? And what kind of EGT temps under boost? I have a Haltech E6k in my car and have it tuned pretty good so far, but am interested to see what the factory is doing and compare that to what I have. Thanks for any help.
Steve
On my setup I run timing in the high 20's to mid 30's cruising. On high boost it drops to 10 degrees and climbs to 18-20 degrees by redline. EGT 820 celsius on high boost and variable while cruising on the highway at 65 its about 700 celsius.
Later,
Thanks for the info. Are you using the stock ECU or a stand alone? How much boost are you running at high boost?
