cagri
- 47
- 1
- Oct 7, 2002
Des Moines,
Iowa
I have been tuning my car again recently now that I got cams put in and the weather is hot.
What I am noticing is that my O2 s are showing .98 at 4000 to .96 at 7000 rpm when going WOT.
I am getting my timing pulled to 5 - 7 when I go WOT around 3500 rpm and it steadily climbs to 19 around 7000 rpm with no dips. If I try to lean it out little bit to bring down O2 values I cannot get more than 17 timing at the top and my timing does not go up as fast, just to make sure I leaned it way out by %7 or so, and my timing dropped to 3 and got up to 13 around 6000rpm which is pretty low and my O2s were still showing .94 to .96.
I remember 5 - 6 months ago, my O2s used to read .92 - .94 with almost the same settings, is it the hot weather that is causing this or is my O2 sensor is going bad?
All pulls are made on 3rd gear(2nd gear reads 1.00V, very rich) at 16.5 psi on 92 octane gas with 650cc injectors on FPBig28. Car is 1998 GSX.
My S-AFC settings are -29 -28 -28 -27 -27 - 26 -26
