4G634ME
- 30
- Jul 12, 2002
Okay, I'm really goin' nuts. My car ('91 GSX, JDM engine w/ 75,000 mi) seemed to be running a bit weird all day, especially in first gear. Having a hunch that timing was being pulled, I checked for knock on the Pocketlogger.
For some reason, I am getting serious knock (40+) under heavy throttle in first gear and ONLY in first gear. Even at the same engine speeds in other gears I get absolutely nothing! Runs perfect!
Can you guys give me a hand with this? I'm really really nervous.
Is this the so-called 'Phantom Knock?'
FWIW:
14B
Walbro 255
Stock injectors
17 psi
AFPR
Manifold leaks (broken studs... waiting for turbo to arrive to put 2G on)
Boost leak (intake test)
Other mods under profile
Gonna go down to 15 psi for now, see what happens. Gotta go, wife is demanding we go to dinner.
Thanks guys....
Jason (off the boost for now)
FWIW:
14B
Walbro 255
Stock injectors
17 psi
AFPR
Thanks guys....
