HIGHPSI4
- 809
- 11
- May 11, 2003
Vale,
North Carolina
My knock sensor is giving me a fit. Typically it pulls timing and dumps all the boost at low throttle. It does not pull all the timing at WOT. The knock sensor has <3000 miles on it. I have tighted, loosened and even pulled it from the block. When I pulled it from the block I got the code 31 and still displayed a knock sum on my logger. I have checked the wiring harness and ground and have switched ECU's and I still have this full knock sum knock. I am going to check the knock sensor with a scope today and have ordered a new knock sensor. Anybody have a clue what's going on. Your input is greatly needed. Thank you!
Ok guys i have a sugestion. I want yall to unplug the Knock sensor and see if ya still get knock like Dave is. If ya still do then I am thinkin there must be some inductance voltage bleeding over into the knock harness. It is shelded but if the sheilding is broken anywhere there can be blead over voltage from any adjacent power wire. this is a weird problem and only investigation will find the solution. good luck.
