What size injectors
THEDUKE
91
Jan 23, 2003
Bristol, Tennessee
I have the 60-1 with the 4S0E cover,stage 3 exhaust .62 , I will be running the big crowler cams. What size injectors should I go with. I have a set of 59lbs delphi will they work or do I need to go bigger. Dont know what size that is in cc.
It would be about 650 660 in ccs dont know if thats what you need or not but that would be a rough cc conversion for ya
Thanks thats a good start knowing what I have. I kinda wanted to know if they would be enough fuel for the turbo I am running. I know alot of other things could play apart in this besides the turbo I am running. This is a fairly big turbo & I see alot of other guys running 720cc injectors. I will run them & see what they do no matter what but I just wanted a good guess from someone that had a turbo this big if they thought I should go bigger on the injectors. I have a very good fuel pump & can go up to 125psi .
660 are good but if your going to push that turbo hard get 720 or 780 cc
More than that it hard to idle unless you had a standalone or DSM link.
Yes thanks, for now I am not running stand along but thought I should go alittle bigger on the injectors. If I can trade the 660 for some 720 I will if not I will run them until I am ready to step it up. Maybe run about 20 psi of boost on the 660. I will log and see. I can always run the juice to go more if I want. I have only played so far but this turbo seems to love the bottle. Thanks again I will carry on.
If you have a stand alone then I would go with 8 550cc. If not then go with the 720cc. I am running them now and I am still running out of Injector when the boost is at 29psi. So soon will run 8 550cc or some 1000cc. 59lbs is just about 600cc.
Luke
