aves911
- 100
- 1
- Nov 13, 2002
Okay, first off this is my setup
AFPR, bfp set at 32psi
720cc
255lph pump
-6AN lines
PTE 50 Trim
Ported O2, and manifold
2.75" turbo back
All honeycombs removed from MAS (except the big center one)
3" Intake pipe
Dejon FMIC with 2.5" piping
6-bolt swap
Now my questions
I just went out and logged my car to try and start tuning it. Second gear pull 26psi. O2's across the board at 0.94v. My EGT's hit 1600 at 7000 in second. But im not getting full spool until over 4K rpm. My timing doesnt drop to 10 degrees until 5100 rpm. From there it jumps to 17 at 6000 and only climbs to 18 at redline. Rich knock is my best guess there and mabey high EGT's from running to rich as well. Only problem is my AFC is already set to -35% from 3000 until 7000rpm. That seams really really lean to me, plus I have the fuel pressure dialed back and the MAS is hacked.
Any pointers as the what I should do next would be great. I'd like to reduce my lag so full boost hits at 3800, and to do this I need to figure out how to get my timing to drop sooner. The best I can figure is that the AFC is set so low that it sends such a low airflow signal to the ECU that the computer doesnt realize the car is under boost until the higher rpm range. On top of that, I can't richen it up anymore or I get rich misfires. But leaning it out to -40% on a 50 Trim at 26psi seams really really lean to me.
Any help is appriciated.
720cc
255lph pump
-6AN lines
PTE 50 Trim
2.75" turbo back
3" Intake pipe
6-bolt swap
Now my questions
Dont go by what you "think" is rich, but by what your knock sensor tells you.
But I just wanted to thank everyone so far for their advice, it was a huge help.
