coolnick
- 68
- May 14, 2003
Cincinnati,
Ohio
I have a 90 GSX with a 14b and a MBC. I rewired the fuel pump and removed the lower honeycomb in the MAS. I logged some runs in 3rd gear at 15 psi and I got about 40 counts of knock and near 0 degrees of timing advancement (on 93 octane). I had to back the boost all the way to 12 psi to get the knock count below 10. I am thinking that a fuel pump may help out a little here. I want to run 16-18 psi if at all possible, will a Walbro 190 allow this, or do I need more of a fuel pump and a AFPR? Does the small screw in the lower section of the MAS make enough of a difference to bother screwing with it (no pun intended).
TIA
TIA
