popping and studdering at low throttle with 550s
Wobble
726
Jan 2, 2003
my car seems to hesitate prteey bad at low throttle shifting from 1st to 2nd and 2nd to third..
I have DSR 550 injectors and a S-AFC, i have the low throttle set at aroun -16 from 1000-3000 rpm.. but the car still pops when i give it the gas after shifting.. i tried richening it up some and leaning it out more and neither seemed to work... i know i will get it sorted out when i put my wideband on this weekend but untill then.. its irritating..
any ideas?
yeah i had used 550 injectors and cleaned them and had the same problem but found out 2 of the 4 were bad and this was what was causing my low end stuttering. idk, if this is your problem but i had mine on a wide band and went lean and rich and never solved the problem, i put the stock ones back on and it ran perfect.
