COspeed
- 72
- Jun 6, 2002
Colorado
I recently swapped out my original MAS that had no lower honeycomb, with a stock one. I was trying to fix my weird fuel trims and gas mileage. The new MAS helped with my fuel problems, but is now causing some other problems. The car went from running fairly lean, to running pig rich. More importantly, I'm hitting MAS overrun in the upper RPMs on only 13 lbs of boost. This seems a little out of the ordinary to me. I'm also at a high altitude (5300 ft) and it has been pretty warm lately (75-80*). I have a datalog of the most recent occurence if anyone is interested...
Relevant mods are:
3" turbo back exhaust
ported 14b, o2 housing, 2g manifold
Walbro 190lph pump
Fuel system upgrade (filter, SS line, -6 AN fuel rail inlet)
boost controller @13psi
Relevant mods are:
Walbro 190lph pump
