awdfun
- 68
- 4
- Mar 2, 2003
Flagstaff,
Arizona
This is a log from last night - What do you all think? I see alot of 1-2 degree dips in timing, and it has me worried. More questions below...
RPM Timing O2 volts
1st gear
3760 11.0 0.94
4496 10.0 0.94
5308 16.0 0.94
6036 20.5 0.96
2nd gear
4352 10.0 0.96
4612 10.0 0.94
4928 13.5 0.96
5172 14.5 0.96
5460 16.0 0.96
5688 19.5 0.96
5932 20.0 0.96
6180 20.0 0.96
6400 18.5 0.96
6596 20.5 0.96
3rd gear
4780 12.5 0.94
4888 12.5 0.96
5072 13.5 0.94
5200 14.5 0.96
5324 14.0 0.96
5444 16.0 0.96
5564 16.5 0.96
5672 16.5 0.94
5800 18.5 0.94
5904 16.0 0.94
6008 17.0 0.94
6092 17.0 0.94
6192 17.0 0.94
6284 18.5 0.94
6376 19.5 0.94
6464 19.5 0.94
6552 20.5 0.94
4th gear
4960 11.0 0.94
5044 12.5 0.94
5124 13.5 0.94
5188 11.5 0.94
5252 12.5 0.94
5296 13.0 0.94
5352 13.0 0.94
5408 14.0 0.94
5444 14.5 0.94
5508 14.5 0.94
5564 14.0 0.94
5612 14.0 0.94
5644 14.0 0.94
5704 14.5 0.94
5748 14.5 0.94
5780 16.5 0.94
5832 16.5 0.94
5880 16.5 0.94
5916 17.0 0.94
5960 17.0 0.94
5980 17.0 0.94
6028 17.0 0.94
6072 17.0 0.94
6092 17.0 0.94
6132 17.0 0.94
6160 17.5 0.94
6192 17.0 0.96
1. Does the ECU retard timing if it sees coolant temps over a certain temp?
2. Same for intake temps - will it retard timing if it sees temps over a certian value?
3. Has anyone been able to correlate the knock counts with timing retard? I have heard the 1g ECU will not advance timing at 3-7 counts of knock, and it will retard timing at 8+ counts. Should I forget about trying to make this correlation and just get a nice steady timing curve?
4. Are the 1-2 degree dips in timing normal, or do I have some knock going on here?
5. What does elevation do to the 2g's in terms of tuning - I know that at 7000 feet elevation I can run much leaner. How is this? Isn't a 12:1 A/f ratio a 12:1 A/f ratio no matter what elevation you are at? Or do I drop in A/f at higher elevations? (sorry, I don't have a WB O2 handy)
6. Is it possible that the T-25 at this elevation just cannot support the 15 psi that I am tuning at - due to the decrease in compressor efficiency at this elevation?
Thanks in advance for any advice you can throw my way!
I have a bunch of parts in my garage that I don't want to install till I understand this a bit better...
RPM Timing O2 volts
1st gear
3760 11.0 0.94
4496 10.0 0.94
5308 16.0 0.94
6036 20.5 0.96
2nd gear
4352 10.0 0.96
4612 10.0 0.94
4928 13.5 0.96
5172 14.5 0.96
5460 16.0 0.96
5688 19.5 0.96
5932 20.0 0.96
6180 20.0 0.96
6400 18.5 0.96
6596 20.5 0.96
3rd gear
4780 12.5 0.94
4888 12.5 0.96
5072 13.5 0.94
5200 14.5 0.96
5324 14.0 0.96
5444 16.0 0.96
5564 16.5 0.96
5672 16.5 0.94
5800 18.5 0.94
5904 16.0 0.94
6008 17.0 0.94
6092 17.0 0.94
6192 17.0 0.94
6284 18.5 0.94
6376 19.5 0.94
6464 19.5 0.94
6552 20.5 0.94
4th gear
4960 11.0 0.94
5044 12.5 0.94
5124 13.5 0.94
5188 11.5 0.94
5252 12.5 0.94
5296 13.0 0.94
5352 13.0 0.94
5408 14.0 0.94
5444 14.5 0.94
5508 14.5 0.94
5564 14.0 0.94
5612 14.0 0.94
5644 14.0 0.94
5704 14.5 0.94
5748 14.5 0.94
5780 16.5 0.94
5832 16.5 0.94
5880 16.5 0.94
5916 17.0 0.94
5960 17.0 0.94
5980 17.0 0.94
6028 17.0 0.94
6072 17.0 0.94
6092 17.0 0.94
6132 17.0 0.94
6160 17.5 0.94
6192 17.0 0.96
