need help picking a gm translator pipe
which do you recomend??
  • draw through
    Votes: 3 23.1%
  • blow through
    Votes: 10 76.9%
  • Total voters
    13
rick
291
Aug 15, 2002
el paso, Texas
ok, i am gonna buy me a gm translator, but ineed to know, what kind of set up to use? draw through or blow through, i want to use blwo through cuz i can get my bov going (i know, shut up). so what do you guys recomend??
1992 eagle talon tsi, 3 inch exhaust no cat, k&n filter with hacked mas and air can. its gonna gte a lot of new toys soon, but the first will be a pocket logger, then a big 16g, lancer manifold, 550cc injecotrs, new web cams and a burschur stage 2 head. also a set of unorthodox pulleys and cam gears, fmic from dejon tool, fluidyne radiator, and an act 2600. i will also get an apex afc and a greddy profec b along with an apex turbo timer.
i love blow thru!....just dont get cheap connectors (home depot) and have them explode on you. oops!
Has anybody installed the 3.5" mas on their car? If so, where did you get your reducers as I'm having trouble finding them.
Thanks.
ChanJr has a blow thru and its SOOOOOOOOOOOOOOOO sweet hearing that BOV coming before you c the car. its a "i'm here mike" signal for me to jump out of the car (the talon i'm NEVER gonna fix) and open the gate for him. if you have any questions he is happy to answer em (he knows alot about these cars). hope that helps.
BTW-i'm doing blow thru also so i can tune AND put the sweet RFL on it :D
What kind of intercooler pipe does he have for the blow-through design?
I dont know if this was suggested, but why not use a header reducer from hedman or hooker that they sell for domestic V8's?
just remove the 3 bolt flange(it slips off) and weld it onto your existing upper IC pipe after the BOV. Its radiused smooth for exhaust, and it has a flange already on the end, so your coupling (3" to 3") wont blow off at high pressure.
Like this : http://store.summitracing.com/partdetail.asp?part=FLO-R3025 Its what I plan on using when I set up mine, after I set up my IC pipes for my FMIC in steel.
If its already common knowledge, sorry.
