What Dyno #'s
cazual
Jan 18, 2003
Hey guys, I am going to the Dyno tomorrow and I want to know what you all think looking at my sig what kind of numbers I should be looking for with my setup. Thanks
"3" Thermanl catback exhaust; "3" custom down pipe with test pipe;16G Turbo; Unorthodox under pulley; 2600 lb ACT clutch and light weight Fidanza flywheel; Walbro 255HP fuel pump rewired; HKS EZ boost controler; guages; SX fuel regulator kit; Ported EVO Manifold; Ported EVO O2 housing; DSMtranslator;SAFC II; logger; ; Buschur FMIC; Tial BOV; 660s.
Depends on type of fuel, boost, temps, what type of dyno...etc
But if all is right Im sure that if tuned good on race fuel and mayb 22-25psi you could get from like 300-320whp...
Thanks, I will by using C16 race gas, on an awd Dynojet.
Just don't be disappointed if the #'s aren't what you expect. Most of the battle is tuning. How much max timing are you getting? EGT's?
If you're using race gas, I would be very dissapointed to see you only make 300 whp.
My car, with a 14b, 2.5 inch exhaust, 450's, and no fuel control, trapped at over 106 mph. That's about 300 whp.
I would hope you would make between 350 and 400 WHP on race fuel.
But, this only will happen if you know how to tune.
Well, I am back from the dyno and I was unable to run the race gas so I had to make my runs with pump. :cry: Anyway, after a couple of hours of playing I managed 301.9 whp and 291.6 torque at 18psi.
I was really and I mean really rich at the top, but we just did not have the time to lean it out enough to see if my numbers would increase. I will make some more runs this coming Friday, to see if I lean her out at the top end.
That's not too bad!
See, I told you you'd make more than 300 whp on race gas.:D
I look forward to seeing what you can do next time!
Originally posted by kpt4321
That's not too bad!
Thanks Kyle. I will let you know.
  • For sale 1g 90 Oil Cooler
    • kyler021
  • For sale 4G63 (Broken) Cusco MZ Center LSD
    Selling a broken Cusco MZ center LSD (not a Tarmac) for DSM/Evo123. This unit failed a magnaflux...
    • Canadian_CD9A
  • For sale 1996 Eagle Talon Tsi AWD - RaceCar Shell
    Rolling Shell
    • Black_Cat_DSM
  • For sale Neat gearbox 4 spider conversion
    I picked up two spare sets of spider gears for a 4 spider conversion as I wasn't sure what the...
    • tstkl
