2g tuning...
Tallen
2,739
8
May 28, 2002
Ashburn, Virginia
what degree of timing should i be seeing at WOT? 15 right?
right now i am seeing 33...according to the TMO site, i should increase boost. anything else i should be looking at, keeping in mind cant see knock. thx
if my timing is like this...shouldi add or take fuel away?
33 at WOT is way way off for WOT. To be getting that much timing, your ECU must think you are flowing very little air. You should probably describe your setup in a little more detail. what turbo @ how much boost, what injectors, what fuel controller and settings. Also, how are you reading the timing, and are you able to read anything else, such as O2 voltages, etc.
Brad
nm, i am getting good timing now....i was looking at the wrong log. whoopsie
