EVTBernie
- 85
- May 4, 2006
South Burlingto,
Vermont
Ok so I just started driving my 92 GSX that I got at the end of the summer and man o man is this thing a dog. Doesnt even compare to my old talon which had almost the same mods. Ok so I dont know much about the car other than it's a solid 6/4 and it has an eprom ecu, upgraded clutch, upper IC pipes with 1g bov, and a full 3'exhaust with O2 dump. I've turned the boost all the way down then turned the BC about 2 small turns and I mean small. When I drive it and mat the gas the O2 dump opens and it's like this things a dog has hardly any pull. When I go to 2nd it has small pull, then third if Im still gas to the floor it chugs and hicups bad. I can't find my data logger to see whats going on but even with boost down it hits like 15-18 psi. It's still snowing slightly here so trying to stand under the hood for hours and working on it is almost impossible. I run only 93 Octane and have checked the turbo for shaft play which it has 0. I have not done a leak down test, compression test or base timing yet but checked my spark plugs and they seemed to be the right color not too black and not too white. There's no shops around here that can work on these cars and I would like to get this thing at a base level so I can work on getting the mods done that I want to do. Any help please?
