8.5 Compression on Stock ECU
greddy_1700
1,037
91
Aug 27, 2006
Regina, SK, Canada
Hey,
Just curious as to whether or not the stock 1g ECU can handle this setup.
The car will be a bone stock 1g 7 bolt engine, with evo springs / retainers, as well as evo pistons and rods. The car will be running a 14b turbo, set to around 15 psi, as well as a rewired Walbro 190LPH pump and stock 450cc injectors.
Do you guys think that the stock ECU could handle this setup, or will I be running lean? This is for a local $500 challenge car, so just looking to see if this bump in compression is worth it, however, I am thinking its not doable without at the least an SAFC.
Evo 8/9 pistons are 8.8:1 X's are 9.0:1
Are you running Evo 1-3 pistons?
My mistake, typing while trying to work results in the brain not working apparently.
Yes I meant 8.8 compression, as I would be using the set of Evo 8 rods / Pistons I have.
So is it safe to assume that the factory ECU would not be able to handle such a bump in compression?
Thanks,
Garret
  • For sale 420A 420a block & EGR/ FUEL RAIL INJECTORS
    90PSI compression test. Possible damaged piston rings, unsure. Possibly good for a...
    • Stizzydrew
  • For sale 420A OEM 420a throttle body
    $40 + shipping + fees (PayPal) Pick up CA 91605
    • Stizzydrew
  • For sale 420A 420a intake manifold
    $80 OBO + shipping + fees. (PayPal) Pick up CA 91605
    • Stizzydrew
  • For sale 420A 420a thermostat housing
    Oem thermostat housing 420a $20 + shipping + fees.
    • Stizzydrew
  • For sale 420A NVG T350
    New venture gear T350 M/T 420a
    • Stizzydrew
