97ebaygst
- 326
- 2
- Oct 8, 2009
thomasville,
North Carolina
I had a problem pop up outta no where that i can't seem to figure out. The car has been driving fine until a few days ago. It started to run rich so I did a log with evoscan and my o2 sensor was logging .1 volts which means lean if I'm right and its not cycling. When the car is not running the volts read above 1v with the highest Ive seen being 4.5v.
I've even unplugged the sensor and logged a reading of like .039v. Can anyone give me any advice on where i should look.
