DDualan
- 98
- Feb 19, 2012
Cumberland,
Rhode Island
so i have a dead stock TSI FWD
the engine is from a 1998 Mitsubishi Eclipse GST only swapped the block and the head
replaced the coil
replaced my ecu
did a compression test
someone told me that it could be the cam position sensor ?
should i just swap it out and run a 1g cas?
are there any other things that could cause no spark on 2/3 ?
I have someone telling me that the Cam Position Sensor from my 1996 car would not work properly with the 1998 cam gears??
replaced the coil
replaced my ecu
