elterror
- 115
- Feb 13, 2011
FORT WORTH,
Texas
Heres my friends GSX got dyno'd tuned and this is what he got.........WTF
Mods are: wally 255 rewired,-10 fuel line,1250 injectors,magnus fuel rail,magnus intake,1g/2g rod - piston setup,hks 264 intake and exhaust speed density set up,nicely modded head,full 3'' inch exhaust,hx35 on .55 ar BEP housing, 38mm tial wastegate....Those are the important mods....Have checked for boost leaks but will check again....Please help I know he should be making more so what gives...Thanks in advance for all help and suggestions.
If you dont know to look at the log you will have to have ECMTuning program installed. Log is 2nd gear pull.
2nd log is the 3rd gear pull sorry.
what wideband do you have and how come you arent logging it? and it could be because who ever tuned your car didnt even touch timing... thats an evo 8 mod 1 map right there unmodified or if it is it barely is. thats just my .02 id get your cash back
