help with fuel question
95tsiawd0330
124
Feb 9, 2012
woodlyn, Pennsylvania
i've been doing WOT pulls trying to get my fuel to be around 11.5.1afr and it has been a pain doing it. everytime i do a pull my fuel would go to 11.5.1, but when it gets around 3400 rpm to 3900 rpms it jumps to around 12.5.1 then back down to 11.5.1. Can someone tell me why this happens? Also here is a log of this happening.
Look at your DA fuel table. Its all in there, the rest is in slight tweaks of mafcomp. But youve obv got it nearly perfect. Atleast from the spectrum i saw, your wbfactor never gets beyond 4% or so.
sorry bud, saw your new post and see your SD. Im not knowledgeable in that area. I saw a maf reading and didnt look at your ecuconfig. Just the DA tables.
thanks for the reply.i have my da tables set the right way i think.also you say that the rest is setting my mafcomp i forgot to mention that i am runnin speed density and i have the check box for disable maf compensation checked since iam on sd.or am i supposed to leave that box uncheck?
Wow I can't get no help from anyone
