Cesarlcase
- 261
- 5
- Dec 29, 2009
lynbrook,
New York
My car was tuned and runs fine on wolf v400 plus ems w/ map sensor (most probably never heard of) but that was on 8lbs. I'm now looking to increase the boost,but I'm not sure what settings are changed to increase fuel with boost/rpm,safely. It has a hand controller which makes use of it very easy. Although every ems is different, the hand controller is very basic and It's literally a left and right button to make adjustments! I really want to learn how,so I hope you guys could give me some useful advice.
Some of the fuel settings I see is:
Fuel enrichment
Fuel enrichment decay/rate
Decel enleanment
Decel enleanment decay/rate
Fuel map load band move
I hope this is enough info for some advice.
Fuel enrichment
Decel enleanment
