1g ECU caps...replacement?
dTERM
352
Jun 5, 2002
Ok, I have a 1990 eclipse GS and I was wondering, where can I get replacement caps for the ECU and where can I find instructions on the best method for removing the ecu from my car and doing the cap install?
www.vfaq.com under electronics.
A little bit of advice. Do not use the solder sucker, those things are crap. Spend the extra time and use copper braid to remove all the solder. Make sure you wipe the board down with acetone before starting to remove the film they put on at the factory.
    • eclipsemf
