Engine dying with radiator fan kicking in.
blackrosenova40
398
4
Jan 12, 2006
Belle Plaine, Minnesota
Just throwing this on here, im sure ill eventually figure this out, just want to see if anyone else has had this problem...
Whenever my radiator fan kicks in my car dies no matter if im at idle or keeping the engine at any higher speed, or cruising down the road.
I can turn on my headlamps, blower fan, all accesories but its only the radiator fan that kills it. Alternator is charging fine. Tested MPI relay, tests good.
