Where to set Base Fuel Psi?
nolv4v8
104
Oct 21, 2002
Milwaukee, Wisconsin
I have a chargedair AFPR and I am wondering what is a good setting for my base fuel psi? I have seen a few different settings and I want to know why they are different? I was going to set it at 43 psi. Thanks. BTW, the reason I need to set it is because I have a 255 pump and it is overruning the stock FPR.
I have mine at 43psi. That's what the injectors are rated at.
I believe its 43 psi with the vacuum line disconnectd from the AFPR. Then once you reconnect it goes down to 30 something and will then rise with boost.
-Dennis
95 Talon AWD
since you have not posted what year your car is i will have to say.
1g= 37-38
2g=43-44
Thanks, mine is a 2G by the way. Do I set it with the vacuum line connected or disconnected? I have seen many arguments about this and I am wondering if anyone has the right answer and can support it. Thanks JDMAWD for the info
Definitely pull the vac line off when you set the base line FP. then reconnect it once you get the baseline to the desired level
    • sanmantsi72
    • El_marto
  • For sale 1G DSM 4G63 PARTS
    • The_Partout_Spot
