mike96
- 1,010
- 22
- May 6, 2008
Phoenix,
Arizona
just about to finish up doing a MAFT gen II install and was just had a couple of questions. i would like a couple of opinions to maybe help push me to make a decision for the final upgrade path. right now i have an EVO3 16G, EVO8 injectors, mild port and polish, and a full exhaust with out cat. i originally had an e-manage in the car that worked pretty good and i have herd that people use an AFC of one type or another to fine tune the base MAFT's but it doesn't seem like some thing i need with the gen II or should i keep the e-manage in for that purpose. i am debating to either up grade injectors later to either 650's or 750's or taking advantage of the e-manages other abilities to run additional injectors and adjust timing. i have my eye on an EVO8 ecu at the moment as a possible upgrade now that it seems that someone has gotten there car running good with one, and DSMlink is a bit out of my price range.
any and all suggestions welcome.
mike
mike
