Phoenix_RsX
- 324
- Jun 28, 2002
I looked up VFAQ for the diagram on the safc install. so I put it in today. and it seemed to go very well until I thought I was done, and still had a yellow, and white wire to deal with. my problem is the diagram doesn't show where to run the yellow or white wire to. One step did say to "solder wire to knock sensor", but doesn't say which wire. If anyone out here knows where to run these wires, it would be greatly appreciated.
and another thing, after installing my walbro 190 lp fuel pump, and 550 cc injectors, I've been wayyyy on the rich side according to both my A/F gauge, and t/t. My car sputters, knocks if I try to step on it, and won't let me drive any faster than 30. How can I set my AFC to stop this?
Thanks again guys.
Thanks again guys.
. I just recieved my EGT gauge the other day. I have the wiring set up, I just need to tap the probe. As for the AFC, I'm still trying to figure that damn thing out.
any sites you know of that I can look at for help? thanks larry.
