Your oppinion
totaleclipse3
68
Jul 29, 2005
Deland, Florida
I just bought a big 16g, an ssac autocrome FMIC, evo fuel pump, and 550 injectors. None of this is installed yet, I plan on putting everything in at once, I also have all the supporting mods I should need, which brings me to my question.
I have an apexy safc to tune and evoscan to log with, I am new to the tunning thing but have read all the information I could find to help learn. What should I initially set the boost at to make a log, I'm on 94 octane (Finally Florida had something on the west coast, LOL) and I'm overal pushing for around 19 to 20 psi and about 280-300 at the wheels. Just don't want to blow anything up. Thanks guys.
I usually start with the stock wastegate pressure(B16Gs come with a 14 psi actuator if I recall correctly). After I get the SAFC dialed in perfectly, I'll hook up the boost controller and add 1-2 psi at a time.
Cool, thanks guys I'll start out with stock boost then, I just thought I read somewhere that you should turn the boost to your desired level when you go to set the apexi, but I'll defenetly go stock first. I appreciate it guys.
  • For sale 420A 420a block & EGR/ FUEL RAIL INJECTORS
    90PSI compression test. Possible damaged piston rings, unsure. Possibly good for a...
    • Stizzydrew
  • For sale 420A OEM 420a throttle body
    $40 + shipping + fees (PayPal) Pick up CA 91605
    • Stizzydrew
  • For sale 420A 420a intake manifold
    $80 OBO + shipping + fees. (PayPal) Pick up CA 91605
    • Stizzydrew
  • For sale 420A 420a thermostat housing
    Oem thermostat housing 420a $20 + shipping + fees.
    • Stizzydrew
  • For sale 420A NVG T350
    New venture gear T350 M/T 420a
    • Stizzydrew
