stevetford
- 89
- Feb 23, 2002
Wickliffe,
Kentucky
I am looking at some of the DIY wide band O2 kits that use the Honda wide band sensor. I have seen some post here where people are saying that the wide band O2 sensor is not designed to stay in the exhaust system because the heat will kill it. My guess is this is not true with the Honda sensor or Honda owners will be relacing the sensor all the time.
Well, my question is where should I install the sensor. I am thinking either before or after the flex section in the down pipe. But is there going to be enough heat to give a proper signal? Obviously I know very little about the wide band sensors so if anyone has any advice please let me hear it. Thanks guys.
Steve
Steve
