Will this throw my tune off?
bob123131
457
2
Dec 20, 2004
winona, Minnesota
I had my car tuned last summer and at the time i had a bad bov diaphram and a 52 percent leak in cylinder 2. Now i fixed cylinder 2 and had a stage 1 to 2 head porting done. When my car was dynoed they put some damn code thing on my safc 2 so people couldnt #### with it. Why they really did it i think is because then my car could only get dynoed there. Anywase now that thats all done im wearing my car in, but when its done will the tune be so off that i shouldnt beat on it at all in fear or running to lean? Psi and everything is still the same. Basically can i be hard on my car for like 2 weeks till my tuning oppointment is up?
Do you have a logger? If so, just do a quick log to make sure everything is running right.
You should really look into buying one there key when upgrading your car. Check out ebay, most of the time you can get a whole logger setup for around $50-60. Well atleast thats what I paid.
How much boost are you running? I wouldnt think it would hurt it, but if I was you I would just take it easy on the car for 2 weeks untill you get it tuned again. Especially sense you dont have a logger and cant monitor what exactly your car is doing.
16 psi on an evo 3 16gt all supporting mods and 560cc injectors. I just didnt know if the slight increase in air flow from the head and better boost due to new bov would throw everything off horably. I kinda want to beat on it a little before going to the dyno ### i would hate to have driven 500 miles goin easy then bring it to dyno and have my new conetic blow first time they go all out you know.
Theres really know way of telling exactly how much its going to affect your tune with out some way of monitoring your car. Each car will react differently to mods. I dont think its going to affect it that much but like I said if I was you I wouldnt beat on it.
  • For sale 1g 1G Turbo Intake Kit
    Used 1G turbo intake kit. Fits on stock intercooler and uses stock BOV. Comes with the MAF and...
    • Badge023
  • For sale 4G63 Used FP 4G63 Turbo Manifold
    Used FP 4G63 Turbo Manifold removed from 1G Talon. Looks okay, needs a cleaning. Did not see any...
    • Badge023
  • For sale 2g Fiberglass Fenders
    2g Fiberglass fenders. Overall good condition. $50 + Shipping/FeesFor faster response Text...
    • 1SlowPOSEclipse
  • For sale 2g 97-99 Mpi relay
    2g. 97-99 Mpi relay. Many don’t realize the later 2g doesn’t use the same mpi as the 90-96...
  • For sale 2g 2g window moulding
    2g pass side window moulding. Rubber is in decent shape. Has one dent. Front plastic end cap...
