Well i was missing two fuel rail spacers since i last changed my injectors, so since the weather was nice today i decided to put in the two spacers back on. Well a couple of things happen: 1st when i tried pulling the spark plug wire from the coil the wire seperated from the plug part that plugs into the coil. So i just reconnected them together. 2nd thing was and this is the important part, when i started the car it kept reving too high at like 2500 rpm but i noticed that when i touched the air flow sensor the rpm went down. Now my question is do you think its the spark plug wire? because i don't think so. Do you think it has to do with the fuel rail or the rail spacers that i put them back on, or do you think the injectors are messed up? Do you think its the air flow sensor? Or the pcv valve since that one broke too!
