Login
 Featured
 Products
Go Back   DSMtuners > DSM Forums > 4G63 DSM Tech > Tuning & Engine Management
Tuning & Engine Management EPROMS, ECU, MAF, knock, EGT, wideband, datalogging, fuel trims, etc. Read this Forum's Strict Guidelines.
Reply
LinkBack Thread Tools
Old 01-07-2003, 06:34 PM   #1 (permalink)
Proven Member
Region: Pacific Northwest
Classifieds Rating: (1)
Reputation: Dieselboy is an unknown
Question about FP Green fuel management
What size Fuel Pump and Injectors are sufficient to provide for an FP Green? Any other fuel management upgrade (BESIDES an S-AFC) I should concider for an FP Green? Also, I know its benificial to rewire the stock pump, should I rewire the aftermarket fuel pump as well when I install the new pump, or should I leave it? Thanks.
____________________________
~Derek~
Offline
Related Auctions
Sponsored Links
Old 01-07-2003, 07:48 PM   #2 (permalink)
Proven Member
Region: Southwest
Classifieds Rating: (0)
Reputation: HighPsi91 is an unknown
I would suggest a Denso Supra fuel pump and 650cc injectors. Rewiring the pump at your stage would be a good idea.
Offline
Old 01-12-2003, 04:56 AM   #3 (permalink)
DSMtuners Supporting Vendor
HiRevPerformance
greentrbo_95gst's Avatar
Region: NorCal
Classifieds Rating: (15)
Reputation: greentrbo_95gst is an unknown
ive been runnin green for over a year and the rest of the setup is ...Haltech E6-K standalone ecu, evo head, 272/272 cams, 190 lph fuel pump and 680 cc injectors......etc
190 lph is totally enought and if you get 650-680 injectors you wont have any problem with fuel pressure (w/ 190) therefore no need for fpr
good luck
pm me if you need any help
www.hirevperformance.net
45psi Sean Burgess Tune
Offline
Old 01-12-2003, 03:49 PM   #4 (permalink)
Proven Member
Thank you, I appreciate that. You pretty much summed up what Ill need. Ill pm you for more questions in the future. Thanks again.
~Derek~
Offline
Old 01-12-2003, 06:48 PM   #5 (permalink)
Proven Member
Classifieds Rating: (2)
Reputation: larryd is an unknown
wow. the 190 is really enough of a pump for the Green? I always thought you would need atleast a 255. Personally I would go over and above whats necesary to stay safe and get a Supra pump and 720s.
Offline
Old 01-12-2003, 10:17 PM   #6 (permalink)
HiRevPerformance
Region: NorCal
Quote:
190 is totally enough. A lot of people always think bigger but when you actually tune the car you can see that it's enough. I've been runnin my denso 190 for a year with built evo head, hks 272/272 cams and 680 inj's and never had any problems. At this stage it's all about tuning. You have to spend at least good two weeks (especially on standalone) to get the car tuned right.
I just added big spearco 2-216 race core, 2.5" piping and Tial bov. Still no problems with the fuel pump.
good luck
Offline
Old 01-12-2003, 10:21 PM   #7 (permalink)
Proven Member
Sweet. Thanks for all the answers. Im sure Ill be turning back to you FP Green powered guys in the future.
One more question, should I do the re-wire mod to the 190 when I get it? Thanks for the helpful info.
~Derek~
Offline
Old 01-13-2003, 12:29 AM   #8 (permalink)
AWDGSXownsU
Posts: n/a
yea you should do the rewire mod. it helps deliver more consistent fuel flow. also i had a friend that ran a FP green with a denso fuel pump. i believe it was a denso 150 re wired with 660's and it was plenty of fuel to put him in into mid 12's.
Manny
92 GSX
Old 01-13-2003, 12:31 AM   #9 (permalink)
Proven Member
Coo , thanks
~Derek~
Offline
Old 01-13-2003, 01:55 AM   #10 (permalink)
HiRevPerformance
Region: NorCal
yes, rewire it.
Offline
Old 01-17-2003, 11:10 AM   #11 (permalink)
Proven Member
Region: Rocky Mountain
Reputation: MrBoost is an unknown
I run a 255lph fuel pump (not rewired), and 550cc injectors with my FP Green, but have a set of 660's I need to swap in and re-tune with DSMLink. I recomend an AFPR though....tuning is a BEEIIIITCH without one! I need one bad!
Offline
[posts] Reply With Quote
Old 01-17-2003, 12:00 PM   #12 (permalink)
Proven Member
Timeslip: 9.985 @ 142.640
Reputation: sleeper142 is more helpful than not
i just got my car started last night... put on the green turbo and tial. I am running 750cc injectors with a whinebro 255 hp pump, however i do have an aeromotive regulator... so that is helpful. But I like what larry has to say, go above and beyone (if you ever decide to upgrade its there) and compensate for it with AFPR or your fuel management whatever it may be.
Albert
Albert Raczynski
Offline
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Page generated in 0.16233802 seconds (80.28% PHP - 19.72% MySQL) with 9 queries
