best fuel pressure regulator?
Originally posted by siueclipse
well, i went and checked that out, but the problem is they only go up to 70 psi. i need one that at least goes to 120.
hehe... i think you missunderstud something :) 70 psi base fuel preasure ir very very hu fuel preasure..
becouse actual fuel presure = base fuel preasure + MAP
if you are runing lets say 30 psi boost and you have 70 psi base fuel preasure your actual fuel preasure would be 100psi..
fuel pumps are not able to pump alot fuel at hi preasure and stock fuel pump can only pump 100L/h at 85 actual fuel preasure :)
usualy base fuel presure for EFI cars is 36-56psi :) injectors are rated at 43 and ment to be used at that preasure :) so why the hell would you need 120 psi base fuel preasure ?
Originally posted by nigma
:] waht does that mean ?
Cliff Notes = a short easy to read version of a book that attempts to explain the basic idea of the book in a simple way.
Your whole big detailed post was the same as saying "He's on crack".
:D
