Find the Ignition Harness for the Turbo Timer
CyberDSM
112
May 7, 2002
Hey guys, I've checked out the vfaq, and tons of other websites but I cant seem to find a pic of where you install wiring harness for a turbo timer to the ignition. I've tried looking under the steering column so many times and I still cant seem to find out where to plug the wiring harness. So...I've taken some under the dash shots with my digicam, if you guys see it can you tell me which pic and point it out for me? By the way, its a 95 Tsi and a Blitz Dual TT w/Greddy TT harness. If any of you 2ger's out there have a turbo timer installed and the pics don't show where to plug it in, can you drop me hint, I'm stuck here.
mine was on the far lower righthand side. It had a white push tab on the backside, but it was otherwise blue. you have to push in on the tab and then disconnect it ..which is quite the pain in the butt..actually, like the hardest thing you have to do. I have a 98 GS-T
I think Im a little late here, but in the second picture (the one of the side of your steering column) behind your blinker there is a white plastic plug that is plugged into your column... that is the plug you use.
Originally posted by coppergst
First picture, the blue harness attached to the key ignition module (almost right in the center of the pic). The harness attaches there.
Considering the VFAQ specifically says the plug is blue, I would be willing to bet you are right. It is the only blue plug of the proper size in any of the pictures, after all.
  • For sale 1g 90 Oil Cooler
    • kyler021
  • For sale 4G63 (Broken) Cusco MZ Center LSD
    Selling a broken Cusco MZ center LSD (not a Tarmac) for DSM/Evo123. This unit failed a magnaflux...
    • Canadian_CD9A
  • For sale 1996 Eagle Talon Tsi AWD - RaceCar Shell
    Rolling Shell
    • Black_Cat_DSM
  • For sale Neat gearbox 4 spider conversion
    I picked up two spare sets of spider gears for a 4 spider conversion as I wasn't sure what the...
    • tstkl
