kchaazz
- 1,166
- 80
- Oct 2, 2002
PENSACOLA,
Florida
Okay, I couldnt find any answers to this issue, so here goes.
My car is always too rich throughout its operating range. Not rich enough to blow clouds of black or stall or stutter, but enough to where my gas mileage is crap, my wideband reads 9.0:1 at wot, and when i burn chips for it with 168 deadtime, global at 32, its still way rich. Ive been using tuner pro lately and playing with fuel maps, and i have to go for a target of 12.98:1 to net 11:1 afr @ wot and at idle my o2 trim sits between 50 to 65% with the low trim @ 82.1% and sometimes higher and ive gone as lean as 16:1 afr target in that area of the map on the chip with little to no effect. So, are my injectors not fully closing or flowing far too much?
Ive got no boost leaks, fp is set @ 37 psi with the vac line off and it a full throttle speed reg so its not a cheapo. I just dont get this, really. Any help will be graetly appreciated.
Thanks, Charles
Thanks, Charles
