Boost leak on turbo? HELP!!
matt98eclipse
1,078
Aug 15, 2006
mesa, Arizona
Hey guys I had a big boost leak some were around the exhaust manifiold,turbo area! Well today i was switching to a 2g exhaust manifold and i did a boost leak test to hear were its leaking and i found out its leaking from my compressor houseing!! In the circle in the picture below is were its leaking air!!!! Its leaking really bad!!
How do i fix this??
UPDATE: Hey guys tonight i redid the clip that holds the compressor housing on and its still leaking pretty bad!! Would it be the Compressor houseing O-ring??
ALSO, i noticed air was leaking out through the oil feed and return holes on the turbo??!!! Is this bad?? Does this mean the turbo is shot??
Ok check out this thread:
http://www.dsmtuners.com/forums/tur...rim-owners-check-your-compressor-housing.html
This thread is about the PTE 50 trim 5031RE turbo and how it leaks from the compressor housing as well. If you go to page 2 it will show exactly where the O-ring sits and then you can make comparisons to your turbo. Also, I looked at your profile and I do understand you have the T3/T4 50 trim, so you could definetly compare the two. Moreover, this thread also gives you ideas on how to maybe fix it but in my opinion, its best to buy the O-ring because boost leaks are just a pain in the butt.
I could have wrote everything for you but it is much easier to refer to that thread made by blcknspooln.
Good Luck, Cheers
Osman
How did the o-ring look? Any flat spots? Also make sure it is seating properly in the groove when you put the turbo back together. Aslo make sure the snap ring is installed with the correct side up. The beveled side faces the turbine housing. I don't know if installing it the other way could cause this problem but just one other thing to check.
As far as air leaking into the oil passage, that does not necessarily indicate a problem. It is normal for some air to leak past during a static pressure test since there is no oil pressure to help seal the oil seals. Have you checked for shaft play, particularly in/out shaft play? Unless air is rushing out into the oil passages I wouldn't be too concerned with that at this point.
dsmulla: Sorry i redid my profile, the 50 trim i had on my old 420a! Thanxs for the link thow! Im pretty sure i put the snapring circlip in right cus theres really only one way it can go in! I even tryed to take pliers and squeeze the clip in more to stop it from leaking and its still leaks like hell!!
    • sanmantsi72
    • El_marto
  • For sale 1G DSM 4G63 PARTS
    • The_Partout_Spot
  • Wanted 4G63 800cc injectors
    • DSM_Thorpe
