Opinion on fuel rail adapter
JCG-GSX
43
Jun 3, 2002
Hey Guys,
I'm thinking about upgrading my fuel system, and I came across this part on DSMTrader that adapts the stock fuel rail to an AN6 fitting. I was planning to run stainless line from the fuel tank up to the filter, and use a K&N high flow AN6 filter. Is this a worthy part, or do you see any potential problems with it? Any advice would be much appreciated. Here is the link:
Fuel Rail Mod
Thanks in advance!
I'm putting together an upgraded fuel system myself using the Steve Tek setup as a basis. I would think that drilling out the fuel rail and using the -8AN to -6AN adapter would be better and cheaper then this adapter which just lets you bolt the AN fitting to the stock diameter opening. But then I don't have the parts handy to measure and compare. Just my thoughts on the subject.
