S-AFC or injectors
mitsugsx95
707
2
Sep 27, 2002
-, Illinois
Im going to start off by saying that i kno i need both, but which one would i get the most out of with the current mods on my car. The S-AFC to tune the stock fuel pump and injectors or go strait to the injectors. Any info would be helpful ( kind of clueless when it come to air/fuel things).
You need the SAFC to tune for bigger injectors, so get the AFC first. If you get the inj. first, the car won't run right.
What kind of performance can i expect out of the S-AFC w/ just having the stock fuel system and injectors?
Depends on the boost you are running. I generally would get AFC, then fuel pump, then injectors, in that order, with intercooler upgraded somewhere along the way.
Not too much.
When you get the AFC, don't you need some sort of monitoring tools such as an EGT gauge and O2 voltage readout, as well as some kind of logging device, in order to keep tabs on what you're doing? The "blue wire mod" enables O2 readings with the AFC, is that right?
yes, without some type of logger or atleast an EGT gauge the AFC is going to do you no good. You will be able to change your fuel trims but if you cant monitor what its actually doing whats the point?
  • For sale 420A 420a block & EGR/ FUEL RAIL INJECTORS
    90PSI compression test. Possible damaged piston rings, unsure. Possibly good for a...
    • Stizzydrew
  • For sale 420A OEM 420a throttle body
    $40 + shipping + fees (PayPal) Pick up CA 91605
    • Stizzydrew
  • For sale 420A 420a intake manifold
    $80 OBO + shipping + fees. (PayPal) Pick up CA 91605
    • Stizzydrew
  • For sale 420A 420a thermostat housing
    Oem thermostat housing 420a $20 + shipping + fees.
    • Stizzydrew
  • For sale 420A NVG T350
    New venture gear T350 M/T 420a
    • Stizzydrew
