Login
 Featured
 Products
Go Back   DSMtuners > DSM Forums > 4G63 DSM Tech > Tuning & Engine Management
Tuning & Engine Management EPROMS, ECU, MAF, knock, EGT, wideband, datalogging, fuel trims, etc. Read this Forum's Strict Guidelines.
Reply
LinkBack Thread Tools
Old 10-30-2005, 03:10 PM   #1 (permalink)
DSM Wiseman
project_tsi's Avatar
Region: Midwest
Classifieds Rating: (12)
DSMLink Here> Installed Cams, Rich Tune, Pump Gas, Lots of Knock!
Alright Im in need of help. 91 FWD. I recently Installed a set of Comp 101200 cams, similar to 272's, and now I have a ton of knock that I can not get rid of. As soon as I hit approx 18 psi the CEL goes off and never quits. My boost is set a 20 psi, but w/ internal gate it creeps to 25 but not like I can keep it floored long enough for it to creep. I am running 93 oct., no means of water/meth injection. A Turbonetics/Bullseye 50 trim at 20 psi, FIC 650's, 255 HP pump, Aeromotive FPR, SBR IC, Blowthrough Maf, yada yada, oh and Innovate Wideband 02. Now as soon as I hit approx. 18psi, I knock but my A/F ratio is approx 10.3 or lower. I have no timing advance, as reset my settings when I installed the cams, and then tried tuning from there w/ no luck. All I want is for the car to pull like it should w/ cams at 20 psi w/out knocking. I am new to this whole DSMLink and even tuning scene so please bear w/ me here. I cannot provide logs right now as my laptop is not w/ me, but if anyone needs more info I can try to provide whatever info you need. Something I tried is advancing my base ignition timing b/c previously before the cams installed I found the car ran better a few degrees advanced but actually now knock is comming on faster than w/ the timing at stock. Should I try retarding base ignition timing a bit? Could I just be running too much boost for the octane level I have? I doubt it b/c someone I know recently installed FP2's and his car is running great on pump gas, so I dunno.
Please help me out, I'll try anything, cus right now $400 worth of new cams is slower than w/out them.
Thanks guys, Dan.
I have also posted this over on the DSMLink Forums so don't tell me to do that!
____________________________
Dan Kasun
93 GSX
05 Ram 1500
06 GSX-R750
Offline
Related Auctions
Sponsored Links
Old 10-31-2005, 07:35 PM   #2 (permalink)
Proven Member
Region: Rocky Mountain
Classifieds Rating: (2)
Reputation: peregrine is more helpful than not
try running like 2* base timing. if youve got the dsmlink you can advance it where you see fit.
John
Offline
[posts] Reply With Quote
Old 11-01-2005, 11:09 PM   #3 (permalink)
Proven Member
diamondgst's Avatar
Classifieds Rating: (4)
Reputation: diamondgst is an unknown
Posibility of rich knock?
Offline
Old 11-02-2005, 01:08 AM   #4 (permalink)
DSM Wiseman
Region: Pacific Northwest
Classifieds Rating: (0)
post a log from dsmlink
Offline
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Page generated in 0.11194992 seconds (71.74% PHP - 28.26% MySQL) with 9 queries
