Login
 Featured
 Products
Go Back   DSMtuners > DSM Forums > 4G63 DSM Tech > Tuning & Engine Management
Tuning & Engine Management EPROMS, ECU, MAF, knock, EGT, wideband, datalogging, fuel trims, etc. Read this Forum's Strict Guidelines.
Reply
LinkBack Thread Tools
Old 11-18-2002, 09:12 AM   #1 (permalink)
Proven Member
Classifieds Rating: (0)
Reputation: 95talontsi is an unknown
fuel pump for agp t28 and 30-50shot.
would a 190 pump be good enough for a big t28 and a small 30-50 shot of nitrous. I heard that the 190 is good for 390 hp, is this right.
Offline
Related Auctions
Sponsored Links
Old 11-18-2002, 09:28 AM   #2 (permalink)
Proven Member
Classifieds Rating: (2)
Reputation: NJGSX96 is more helpful than not
The 190 would be good enough. I would suggest, however, the Supra pump. Couple bucks more for a much better fuel pump.
____________________________
Rich
Offline
Old 11-18-2002, 09:39 AM   #3 (permalink)
Proven Member
don't I need a afpr with a supra pump.
Offline
Old 11-18-2002, 10:01 AM   #4 (permalink)
Proven Member
Do you NEED one with a Supra pump? No. Is it recommended? Sure, but I would recommend one for everyone who modifies their DSM.
Ask yourself this. How much boost you plan on running? Do you think the AGP turbo will be the last turbo for your car? How much nitrous you plan to run? Will that 30-50 shot be the most you ever pump through the car? How far do you plan to modify the car?
If your answers are that the AGP T28 will be the only turbo you run and that 30-50 shot is the only shot you go with and that you plan to mod the car around that setup, then get the 190. That seems to be what you have your mind set on anyway.
Rich
Offline
Old 11-19-2002, 12:52 AM   #5 (permalink)
Proven Member
Reputation: larryd is an unknown
Quote:
do you really think the 190 would be enough for the T28 and nitrous?? I would say thatd be pushing it...
Offline
Old 11-19-2002, 09:13 AM   #6 (permalink)
Proven Member
My 190 was "just" enough for a 20G. I can't see it not being enough for a T28 and a small shot. but like I said, I recommend the supra pump. All the fuel pump you'll ever need.
more and more the majority of the DSM community is becoming a group of people who want "just enough" mods. The 190 pump is "just enough".
Rich
Offline
Old 11-19-2002, 11:40 PM   #7 (permalink)
Proven Member
this is true.. I could have saved myself $$ in the beginning if I had just went with the Supra pump i have now instead of the 190 since I decided to upgrade. Or I should say was forced to upgrade
Offline
Old 11-19-2002, 11:50 PM   #8 (permalink)
Vendor
Reputation: Z1500 is an unknown
You want +30-50hp? L1R. You don't need to keep filling it at $30 a pop.
Kevin
www.agpturbo.com
Offline
Old 11-20-2002, 12:25 AM   #9 (permalink)
Proven Member
true true.. would you say the same about the L2R + 30-50 Kevin.. jut get an L3R
Offline
Old 11-20-2002, 01:18 AM   #10 (permalink)
Vendor
Quote:
In everybody's car BUT your's
You are going to need more than 10 degrees of advance to get any power out of that car.
IM me with an update on your car, it's got to be running better by now.
Kevin
Offline
Old 11-20-2002, 01:24 AM   #11 (permalink)
Proven Member
uhm no, its actually running worse
Offline
Old 11-20-2002, 07:40 AM   #12 (permalink)
Proven Member
is wrong with your car Larry? What did you do to make it run worse?
Rich
Offline
Old 11-20-2002, 07:43 AM   #13 (permalink)
Proven Member
Quote:
Again, not what the masses want to hear. It is much cooler to say you have an upgraded turbo AND nitrous, I mean, Nos, than it is to say you just have just a big-a$$ turbo, even if it can whoop on everything in site. Hell, just saying you have Nos is worth it's weight in gold and means you got a fast car, right?
Rich
Offline
Old 11-20-2002, 09:20 AM   #14 (permalink)
Proven Member
not to hijack the thread but broken parts waiting to be replaced.
Offline
Old 11-28-2002, 12:01 PM   #15 (permalink)
Proven Member
Reputation: CL MaNTis GST is an unknown
Where is the best place to get a Supra fuel pump?
Offline
Old 11-28-2002, 03:01 PM   #16 (permalink)
Proven Member
www.partznet.com
Offline
Old 11-28-2002, 11:34 PM   #17 (permalink)
Proven Member
Region: Rocky Mountain
Classifieds Rating: (6)
Reputation: herostar is more helpful than not
deffinately, and on the subject of the 190 w/ a 35 shot... what injectors do you guys recommend?
Offline
Old 11-29-2002, 02:06 AM   #18 (permalink)
DSM Wiseman
550's
Austin
Offline
Old 11-29-2002, 05:21 AM   #19 (permalink)
Proven Member
Reputation: Tom Sawyer is an unknown
Kevin
www.agpturbo.com
Uh Kevin, you neglected to mention that $1300+(misc turbo install parts)-650=$700 that could be spent on other supporting mods for only an additional 30-50hp potential? I dunno, that math doesn't work for me.
Tom
Tom Hughes
Offline
Old 11-30-2002, 07:31 AM   #20 (permalink)
DSM Wiseman
DSMJim's Avatar
why a supra pump what is it's flow rateing? their not exactly cheap either at $180. You can get a 255lph from www.jdsperformance.com for less money than a supra pump.
-Jim
Offline
Old 11-30-2002, 04:11 PM   #21 (permalink)
Proven Member
Region: New England
Reputation: badgsx is an unknown
Whats the comparison between the supra pump and the walbro 255lph? Is one better than the other? Doesnt the supra pump need modification to fit right?
Offline
Old 11-30-2002, 09:10 PM   #22 (permalink)
Proven Member
a supra pump that is rewired flows 290 lph @ 43psi fuel pressure. the Walbro is 255 and the supra pump is quiet like stock, the walbro is also known as whinebro
Offline
Old 12-01-2002, 11:00 AM   #23 (permalink)
Proven Member
Region: Southwest
Reputation: taylorspl is an unknown
Yes the supra pump is quiet since it comes in a luxury sports car. Also if you are going to spray make sure you get a wet kit.
Offline
