Login
 Featured
 Products
Go Back   DSMtuners > DSM Forums > 4G63 DSM Tech > Tuning & Engine Management
Tuning & Engine Management EPROMS, ECU, MAF, knock, EGT, wideband, datalogging, fuel trims, etc. Read this Forum's Strict Guidelines.
Reply
LinkBack Thread Tools
Old 06-26-2005, 10:22 PM   #1 (permalink)
DSM Wiseman
project_tsi's Avatar
Region: Midwest
Classifieds Rating: (12)
What PSI to run? Stock 6 bolt bottom/50 trim w/ sup. mods
I would like to know what is a safe PSI to run at for my daily driver. Mods will be as followed. Gas will be 93 octane everyday. Tuning will be w/ Palm pilot, Maf Translator, and S-AFCII. Basically Im wondering what is safe for a stock 6 bolt bottom end. Will 22-23 psi be fine daily on 93 oct? I think this would be a good overall setup, just need to know what to push for a DD. Thanks for all the help.
Stock 6 bolt Bottom End
Balance Shafts Removed
Cometic Head Gasket
ARP Head Studs
3" Turbo Back RNR Ex. including 02 housing
DejonTool 3" intake
3" GM MAF
MAF Translator V. 2
SBR G50-50 trim turbo internally gated-38mm w/ SS lines
SBR "Street" FMIC kit w/ blow through setup
SBR Ported Cast Ex. Manifold
Walbro 255 HP pump
Aeromotive FPR
650cc FIC injectors
S-AFC II
Palm Data Logger
EGT, A/F, Boost, Oil Press. Guages
MSD plug wires
ACT 2100 clutch
RFL BOV- To scare the shit of the kiddies!
____________________________
Dan Kasun
93 GSX
05 Ram 1500
06 GSX-R750
Offline
Related Auctions
Sponsored Links
Old 06-26-2005, 11:15 PM   #2 (permalink)
Proven Member
gotgrip666's Avatar
Region: Tri State
Classifieds Rating: (0)
Reputation: gotgrip666 is an unknown
20-24 psi
Offline
Old 06-26-2005, 11:25 PM   #3 (permalink)
Proven Member
Region: Mid Atlantic
Classifieds Rating: (33)
Reputation: 1993eclipseGS is extremely helpful and trustworthy1993eclipseGS is extremely helpful and trustworthy
I'm not trying to sound like an asshole but I don't think you can ask that, Maybe you can get an estimate of the boost level, But anyone telling you a set psi you can run should not post. You need to log the car, And have it tuned. You can't just turn the boost up to what someone else thinks you can run, Just because they run that amount or they know someone that knows someone that their friends friend ran that set psi.
Offline
Old 06-26-2005, 11:33 PM   #4 (permalink)
DSM Wiseman
Region: Midwest
Quote:
I know exactly what you mean, and that thought crossed my mind while I was posting. I should have posted it better. I know theres no exact PSI to run on my car, everyones car is a little different and will react different to the way that I tune things. I just need to know what can a 6 bolt bottom end take daily running 93 octane, like a max SAFE PSI. I know that stock 6 bolts have seen 450 hp but i have no idea what PSI they are running. So, sorry the confusion and help me out. Thanks again, Dan
Dan Kasun
93 GSX
05 Ram 1500
06 GSX-R750
Offline
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Page generated in 0.12314510 seconds (71.49% PHP - 28.51% MySQL) with 9 queries
